Add Algorithm
Add a new algorithm as follows:
• Algorithm: CM EXPDT-iii.
• Description: Date must be a future date
• Algorithm Type: CM ADHV-iiiJ
• Effective Date: 1/1/2005
• Parameters:
◦ Sequence: 1, Parameter: blank
◦ Sequence: 2, Parameter: blank
◦ Sequence: 3, Parameter: YYYY-MM-DD
◦ Sequence: 4, Parameter: YYYY/MM/DD
◦ Sequence: 5, Parameter: MM-DD-YYYY
◦ Sequence: 6, Parameter: MM/DD/YYYY
◦ Sequence: 7, Parameter: MM.DD.YYYY
◦ Sequence: 8, Parameter: 0.001
◦ Sequence: 9, Parameter: 0
