Property | Detail |
Purpose | Create javadocs from custom source code. |
Description | This script runs the javadoc tool bundled with the jdk against CM source code in the standard directory and targets the javadocs directory in the Application Viewer. To integrate the javadocs with the product's javadocs the reindex tool needs to be run. |
Usage | generateJavadoc.bat |
Parameters | None. |
