Building the Application Viewer
The Application Viewer is used to display information extracted from products. This information is stored in the form of XML files. These files are built using a combination of batch jobs (run from Batch Job Submission) and utility scripts.
Each process (batch job or utility tool) can be run independently as each of them is responsible for creating separate Application Viewer components.
Parent topic
