Creating MOs and Maintenance Transactions
A typical development of a new MO and its corresponding maintenance transaction entails the following steps:
• Create database objects, e.g., tables, indexes, etc.
• Enter database type of meta-data using online application from the Admin Menu. This includes:
◦ Field
◦ Table
◦ Table/Field
◦ Constraints
• Enter MO meta-data using the online system from the Admin Menu.
• Create the entity, changeHandler, and maintenance impl (implementation) classes using Eclipse.
• Generate artifacts based on the impl classes using the Artifact Generator. The artifact generator must also be executed whenever annotations and/or meta-data are changed.
• Add business rules on either the entity or changehandler using Eclipse.
• Create business components, if necessary, in Eclipse.
• Create test classes and then execute JUnit tests in Eclipse.
• If necessary, update maintenance impl class annotation to include fields with derived values using Eclipse. Regenerate artifacts after changing annotation. This generates the service metainfo.
• Add business logic on maintenance impl classes using Eclipse.
• Create maintenance test classes and then execute JUnit tests in Eclipse.
• Create search impl classes using Eclipse.
• Create search test classes and then execute JUnit tests in Eclipse.
• Create a new Maintenance Object from the Admin Menu -> Maintenance Object. This would automaticaly create the Tab Menus and Tab Pages necessary for a new transaction. This will also create the appropriate navigation key for each program component.
• Create javascript user exits for UI program components (e.g. tab menu, tab page, list grid, etc.).
• Add security access to the new application service.
• Create Menu entry for new application service.
• Launch Tomcat server and test the new application service.
Building General Purpose Maintenance Classes
The steps for developing general-purpose maintenance classes are similar to those for MO-based maintenance classes, as described above, but without the need to rely on entity or MO metadata.
• Create the maintenance impl (implementation) classes using Eclipse.
Parent topic
