Debugging
There are several debugging facilities that help make portal zone development easier.
First, you should get the service working properly before worrying about the zone's HTML. For e.g you can invoke the service through a browser and see the result (as localized XML) using this URL from a browser already logged-in to the Oracle Utilities Customer Care and Billing system:
http://<server>:<port>/portal?type=raw&service=CILFAFHP&ACCT_ID=5922116763&PER_ID=...
Note the required parameters are the service and the keys. Don't put quotes around string arguments.
The example below shows the output of the CILCALZP service (http://<server>:<port>/portal?type=raw&service=CILCALZP&ACCT_ID=5922116763):
<?xml version="1.0" encoding="UTF-8" ?>
<pageBody actionFlag="" metaInfoKey="CILCALZP">
<list name="ZONE">
<listHeader/>
<listBody>
<field type="string" name="FIELD_LABEL"></field>
<field type="string" name="FIELD_VALUE">Comment Exists On Account</field>
<field type="string" name="TOOLTIP_LBL_FIELD">GO_TO_ACCOUN_LBL</field>
<field type="boolean" name="CHILD_ROW">false</field>
<field type="string" name="SORT_KEY">ACCT</field>
<field type="string" name="NAVIGATION_KEY">accountMaint</field>
<field type="string" name="MENU_NAME"></field>
<list name="KEY">
<listHeader/>
<listBody>
<field type="string" name="KEY_NAME">ACCT_ID</field>
<field type="string" name="KEY_VALUE">5922116763</field>
</listBody>
</list>
</listBody>
<listBody>
<field type="string" name="FIELD_VALUE">Account used in Billing test Plan</field>
<field type="string" name="SORT_KEY">ACCALT</field>
<field type="string" name="NAVIGATION_KEY">accountMaint:9</field>
<list name="KEY">
<listHeader/>
<listBody>
</listBody>
</list>
</listBody>
<listBody>
<field type="string" name="FIELD_VALUE">Cable Customer</field>
<field type="string" name="TOOLTIP_LBL_FIELD">GO_TO_SERVIC_LBL</field>
<field type="string" name="SORT_KEY">SATYPE</field>
<field type="string" name="NAVIGATION_KEY">saMaint</field>
<list name="KEY">
<listHeader/>
<listBody>
</listBody>
</list>
</listBody>
</list>
</pageBody>
Parent topic
