Display Usage
To display the usage information, execute the utility without any parameters from the Windows command prompt.
perl extractCMSource.plx
extractCMSource.plx -s sourceDirectory -d destinationDirectory -v Version
[ -n subDirectoryName ] [-m CmOwner ]
-v Version
The Version Number to attach to this release of
the Customer Modifications.
-s sourceDirectory
sourceDirectory is the location to extract from.
destinationDirectory is the location in which the extracted files
are placed. The program then creates a subdirectory under the
destinationDirectory to hold the patch.
-n subDirectoryName
Subdirectory under "Directory" in which this patch will be placed.
If this parameter is not provided, an automatic directory name
is generated based on the environment name and date/time.
-m CmOwner
Used for a Multi-CM jar enhancement, this optional parameter
specifies the CM owner that needs to be extracted from the
project directory (e.g., "cm01"). If not specified, the script
uses the default "cm".
Parent topic
