Example
The following is a sample interceptor and configuration file, where one interceptor class implements all four interfaces.
Configuration file CMServiceConfig.xml:
<ServiceInterceptors
<Service name="CMLTBTCP">
<Interceptor action="add">
com.splwg.cis.interceptortest.InterceptorTest
</Interceptor>
<Interceptor action="change">
</Interceptor>
<Interceptor action="delete">
</Interceptor>
<Interceptor action="read">
</Interceptor>
</Service>
</ServiceInterceptors>
Class com.splwg.cm.interceptortest.InterceptorTest:
package com.splwg.cm.interceptortest;
import com.splwg.base.api.serviceinterception.IAddInterceptor;
import com.splwg.base.api.serviceinterception.IChangeInterceptor;
import com.splwg.base.api.serviceinterception.IDeleteInterceptor;
import com.splwg.base.api.serviceinterception.IReadInterceptor;
import com.splwg.base.api.service.PageBody;
import com.splwg.base.api.service.PageHeader;
import com.splwg.base.api.service.RequestContext;
public class InterceptorTest implements IAddInterceptor, IChangeInterceptor,
IDeleteInterceptor, IReadInterceptor {
public PageBody aboutToAdd(RequestContext context, PageBody in) {
System.out.println("aboutToAdd: " + in);
return null;
public void afterAdd(RequestContext context, PageBody added) {
System.out.println("afterAdd: " + added);
public PageBody aboutToChange(RequestContext context, PageBody in) {
System.out.println("aboutToChange: " + in);
return null;
public void afterChange(RequestContext context, PageBody changed) {
System.out.println("afterChange: " + changed);
public boolean aboutToDelete(RequestContext context, PageBody in) {
System.out.println("aboutToDelete: " + in);
return true;
public void afterDelete(RequestContext context, PageBody in) {
System.out.println("afterDelete: " + in);
public PageBody aboutToRead(RequestContext context, PageHeader in) {
System.out.println("aboutToRead: " + in);
return null;
public void afterRead(RequestContext context, PageBody result) {
System.out.println("afterRead: " + result);
Parent topic
