FW Utility to extract CM sources from Unix environments
The following utility, delivered with the Oracle Utility Application Framework, is to extract CM sources from a Unix environment (note that extractCMSource.plx is the Window only utility):
$SPLEBASE/bin/extractCMSourceUNIX.sh
Usage:
-v <version>
The Version Number to attach to this release of the Customer Modifications. (Example: CM001)
-t <target directory>
Target Direcory is where the extracted files will be placed. This program will then create a subdirectory under that directory for the patch with a timestamp. with a timestamp.
-e
Include CM Application Viewer and Help files (optional).
-l
Language Code when extracting CM Help files (optional).
Parent topic
