How Can I Override the Processing After a Change/Add?
If you need to intervene in the processing after the system successfully completes a Change or Add operation, define the function privatePostChangeSucceeded() or privatePostAddSucceeded() in your TabMenu user exit file. The function should return a boolean to indicate whether the system should refresh the UI with the newly returned server data. You'd want to return false if e.g. you navigate to a different TabMenu.
Example :
function privatePostAddSucceeded() {
var model = parent.model;
var modeFlag = model.getValue('COMPL_NAV_MODE_FLG');
var navKey = model.getValue('COMPL_NAV_KEY');
var complSw = model.getValue('CMPLT_CLICKED_SW');
if (complSw && model.getValue('ENRL_STATUS_FLG') == '30') {
if (modeFlg && navKey){
if (modeFlag == 'G') {
parent.tabPage.gotoContext(navKey);
return false;
} else if(modeFlag == 'A') {
parent.tabPage.addContext(navKey);
return false;
return true;
Parent topic
