Other
• Depending on the data distribution, search on optional index column will likely to cause time out. See example -
• Select BSEG_​ID
• From CI_​BSEG
• Where MASTER_​BSEG_​ID = &IN.MASTER-BSEG-ID
• For such cases, consider additional restrictions or re-create the index to become composite - MASTER_​BSEG_​ID + BSEG_​ID.
