Item | Directory | Content |
Java sources | java\source\cm\com\splwg\cm.domain | Java source code. |
AppViewer files | splapp\applications\appViewer\data\source\CM | App viewer source code files. |
splapp\applications\appViewer\data\xml\CM | App viewer XML files. | |
Web Application | splapp\applications\root\cm | UI code. |
splapp\applications\root\WEB-INF\lib | cm.jar file is deployed here. | |
XAI Application | splapp\applications\XAIApp\WEB-INF\lib | CM?*.jar file. cm.jar file is deployed here. |
MPL Application | splapp\mpl\lib | CM?*.jar file. |
Standalone Application | splapp\standalone\\lib | CM?*.jar file. cm.jar file is deployed here. |
Help files | splapp\applications\help\XXX\cm | Help files segregated by language. |
XAI Schemas | splapp\xai\schemas\CM*.xml | XAI schemas. |
Service XML files | splapp\xmlMetaInfo\CM*.xml | Service XMLs for Java. |
Eclipse Launch Scripts | SPLSDKCommon\eclipseLaunchScripts | Eclipse launch scripts. |
Eclipse Project | SPLSDKCommon\eclipseProject | Project configuration information for Eclipse. |
Software Development Kit Tools | SPLSDKCommon\tools | Tools required by the Software Development Kit. |
