Project Repository
The project repository serves the following purposes:
• It is the central storage for all completed, unit-tested code.
• It provides the environment from which to build the latest state of the project.
• It provides the latest state of the project dev app server from which all developers can synchronize with.
• It is the source for CM Packaging.
To support these purposes:
• It has to be accessible to all developers.
• It is set up as a development client, e.g., similar to a development workstation (see Development Workstation below).
