SPL Service XML Metainfo Files
The OUAF system represents the structure of a service using an XML document (loosely akin to an XML schema). Every service is defined with a single XML document, which is generated based on the Java class information.
Service XML documents are created by using annotation-based metainformation combined with system metadata (stored in the database).
Parent topic
