Services
Select Admin Menu, Service Program to maintain service programs.
Services Object View
Description of Page
Define a Service Name for your new service.
Warning:
If you introduce new services, you must prefix them with CM. If you do not do this, there is a possibility that a future release of the application could introduce a new service name with the name you allocated.
Owner indicates if this service is owned by the base package or by your implementation (Customer Modification). The system sets the owner to Customer Modification when you add a service. This information is display-only.
Description describes the service.
Service Type indicates whether the service is a Java Based Service.
This Program Component grid shows the list of program user interface components associated with the service. For a stand-alone XAI service this list is optional.
Where Used
Follow this link to open the data dictionary where you can view the tables that reference CI_MD_SVC.
Parent topic
