Testing Change on Maintenance Class
Next, a new read is performed (using the same read header above), and you can perform a change to the page body in the method:
protected PageBody changedPageBody(PageBody original)
Here is an example:
protected PageBody changedPageBody(PageBody original) {
original.put(Maintenance.STRUCTURE.ACCUM_ALL_INST_SW, Boolean.TRUE);
ItemList list = original.getList("BCP");
ListBody param = (ListBody) list.getList().get(0);
param.put(Maintenance.STRUCTURE.list_BCP.DESCR50,
"Changed parameter 1");
param.prepareToChange();
return original;
A read is performed after the above changes are sent, and the results are compared.
Parent topic
