Using the External User Exit Templates
All the external user exit templates are located in the \cm_templates directory. Once the UI Program to be extended is known, the appropriate user exit template can be selected from the templates directory.
• Use any editor that supports the JSP file editing and open the approprite user exit.
• Determine the base user exit around which to insert your external user exit.
• Uncomment the necessary functions, and add your code.
• Save the external user exit file as ext_<JSPfilename>.jsp under the \cm directory. Where JSPfilename is the JSP file you want to extend.
• Test.
Parent topic
