XSLT File (/WEB-INF/xsl/linkValueGrid.xsl)
The XSLT transform extracts fields by name from the service buffer XML document, and injects them into the HTML output.
Field | Role |
FIELD_VALUE | Supplies displayed text. |
NAVIGATION_KEY | Provides navigation option. |
KEY | List of up to six context keys. |
CHILD_ROW | Boolean that forces a slight left-indent. |
The LabelValueGrid is similar, but it uses MENU_NAME to define the desired context menu.
(Reuse directly).
<?xml version="1.0" encoding="UTF-8" ?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSLTransform">
<xsl:output method="html" />
<xsl:strip-space elements="*" />
<xsl:param name="sequenceId" />
<xsl:param name="service" />
<xsl:include href="include.xsl" />
<xsl:include href="valueGridInclude.xsl" />
<xsl:template match="listBody">
<xsl:variable name="navKey" select="field[@name='NAVIGATION_KEY']" />
<xsl:choose>
<xsl:when test="string-length($navKey) > 0">
<xsl:variable name="onclick">
<xsl:text />handleGotoContext('<xsl:value-of select="$navKey"/>'<xsl:text />
<xsl:call-template name="emitKeys" />
<xsl:text />)<xsl:text />
</xsl:variable>
<tr>
<xsl:variable name="label">
<xsl:call-template name="title" />
</xsl:variable>
<xsl:call-template name="rowClass" />
<xsl:call-template name="linkValueCell">
<xsl:with-param name="value" select="field[@name='FIELD_VALUE']" />
<xsl:with-param name="onclick" select="$onclick" />
<xsl:with-param name="indent" select="field[@name='CHILD_ROW']" />
<xsl:with-param name="label" select="$label" />
</xsl:call-template>
</tr>
</xsl:when>
<xsl:otherwise>
<xsl:call-template name="valueCell">
</xsl:otherwise>
</xsl:choose>
</xsl:template>
</xsl:stylesheet>
Parent topic
