Oracle Utilities Application Framework API Reference Guide
Introduction
What are the Public APIs?
What are Not APIs?
Changes and Deprecations
OUAF Release 4.0.0.0
com.splwg.base.domain.common.algorithm.Algorithm. getActiveVersion
com.splwg.base.support.algorithm.AbstractAlgorithmComponent. setAlgorithm
com.splwg.base.support.algorithm.AbstractAlgorithmComponent. setParametersFrom
OUAF Release 4.0.2.0
com.splwg.base.support.FrameworkSession.clear
com.splwg.base.support.FrameworkSession.flush
com.splwg.base.domain.common.maintenanceObject. MaintenanceObjectInfomationAlgorithmSpot.setEntity
java.util.HashSet Behavior Change
OUAF Release 4.1.0.0
Deprecation: com.splwg.base.api.batch.AbstractThreadWorker.rollbackToSave Point
Deprecation: com.splwg.base.api.batch.AbstractThreadWorker.setSavePoint
OUAF Release 4.2.0.0
com.splwg.base.api.batch.AbstractThreadWorker.getActiveBatch Thread
com.splwg.base.support.context.FrameworkSession. getConnection
OUAF Release 4.2.0.1
Bug Fix: com.splwg.base.support.context.HibernateCacheHelper. flushAndClear
Bug Fix: com.splwg.base.api.PreparedStatement (Constructor)
OUAF Release 4.2.0.2
Bug Fix: com.splwg.base.domain.common.masterConfiguration. MasterConfiguration_Id (Constructor)
Bug Fix: com.splwg.base.domain.common.businessObject. MessageRepository.businessObjectStatusOptionReplacedBy
OUAF Release 4.3.0.0.0
com.splwg.base.domain.common.businessObject. BusinessObjectEnterStatusAlgorithmSpot
com.splwg.base.domain.common.businessObject. BusinessObjectExitStatusAlgorithmSpot
Alta Look and Feel
Bug Fix: JS API - handleExpand/handleCollapse Methods in xslInclude.js
OUAF Release 4.3.0.2.0
Removed Two-decimal Money Limitation
OUAF Release 4.3.0.4.0
API to access Oracle JET
Oracle Utilities Application Framework 4.5.0.1.1 API Reference Guide
