Creating Javadocs for CM Source Code
Javadocs can be created for CM source code. They are designed to be integrated into the product's Javadocs.
The product's Javadocs are only delivered for objects or supporting objects that are intended to be referenced by CM code. For instance, only the domain and api packages are included, and some of the files created by the artifact generator are not delivered since they have no practical relevance to CM code. These files have been deliberately and explicitly omitted when creating the product's Javadocs.
Note that the process that generates Javadocs on CM source code is not selective, and running Javadocs on CM source code may include more object types than what is delivered with the product's Javadocs.
Refer to Creating Javadocs for CM Source Code for more information.
