Test default actions on Entity Page Maintenance Class
In addition, all defaults that are registered for a page maintenance must also be tested. This should be done through separate tester methods for each default, calling the FW support method public PageBody executeDefault(PageBody pageBody, String defaultValue)
public void testDefaultChg() {
PageBody input = new PageBody();
// TODO populate inputs for default
// e.g.
input.put("FK", "FK CODE");
PageBody output = executeDefault(input, "CHG");
// TODO compare the outputs
// e.g.
assertEquals("FK Description", output.get("FK_DESCR"));
Another example for testing the default on the field which in on the list.
public void testDefaultAlogrithm() {
ItemList itemList = new ItemList();
itemList.setName("MRRA");
List list = new ArrayList();
itemList.setList(list);
ListBody listBody = new ListBody();
listBody.put("MRR_ACTN_ALG_CD", "MRRCRESVCCC");
list.add(listBody);
input.addList(itemList);
PageBody output = executeDefault(input, "AAD");
ItemList outList = output.getList("MRRA");
List outputList = outList.getList();
ListBody body = (ListBody) outList.getList().get(0);
assertEquals(body.get("MRRA_DESCR"),
"Create Service Customer Contact");
The input page body should be populated with the expected inputs for the default action, while the output should be compared against the expected output.
