Configuration of Encrypted Fields
To define a field to encrypt an option must be added with the following attributes:
Option Type should be set to Field Encryption.
Sequence should be an appropriate sequence number. Typically, this is a number that is not used already. Higher number values override lower level sequences.
In the value you need to specify the specification of the encryption in the format of a command string.
table
Table Name.
Table must exist in meta data.
table="SC_USER"
field
Field to encrypt. Field must exist in metadata.
field="FIRST_NAME"
alias
Keystore alias to use to encrypt the data
alias="ouaf.system"
where
Filter for data.
Useful for child tables to determine specific values to encrypt
where="ID_TYPE_CD='SSN'"
wrap
Whether the value should wrapper with the ENC() marker. [true|false]
wrap=false
maskAlg
If the field is also to be masked, then the algorithm to mask the data.
maskAlg="CMCCR"
maskField
If the field is also to be masked, then the field to use as the mask
maskField="CNBR_MASK"
hashAlias
If the field should be hashed, then the alias in the keystore to use
hashAlias="ouaf.hmac.system"
hashField
If the field should be hashed, then the field to use as the hash value
hashField="CNBR_HASH"
encryptedField
If the output from the encryption is to be stored on another field in the table, specify the field name.
encryptedField="PK_VAL2"
For example:
table="F1_ATTACHMENT",field="PK_VAL5",alias="ouaf.system",encryptedField="PK_VAL2",hashAlias='HmacSHA256-1024',hashField="PK_VAL3", where="PK_VAL1='Encrypted'"
There are a few guidelines when using this facility:
The aliases specified in alias and/or hashAlias must exist in the keystore used for the product.
Fields to be encrypted must be in string format only. Other field formats are not supported.
If using a higher level of encryption may increase the storage requirements for a field. If this is the case, adding an encryptedField to hold the larger encrypted value.
The wrap field should be set to false unless additional processing in your code is included to handle the special marker. Product fields should use wrap=false. Wrapping an encrypted value can be useful in knowing whether a specific data is encrypted in cases where only some data on the table is encrypted.
Ad-hoc characteristics cannot be specified in the WHERE tag.
Hashing the value is handy for additional verification and indexing values.
Note: If encryption is added or changed, the F1-ENCRS and/or F1-ENCRT must be executed to reflect the changes.
