Federated Security Support
In some security architectures, the identity used by an individual user can be shared across identity systems. Typically, this is used for cloud implementations where the product or identity is housed on a cloud system and needs to be shared across on-premise and cloud systems. This is the basis for the support of Federated Security within the product.
The Federated Security Support is supported for the following:
Federated Single Sign On Support for the online channel.
Support for OAuth2 tokens for Inbound Web Services.
Support for OAuth2 tokens for inbound RESTful Web Services.
Support for OAuth2 tokens for outbound calls to external SOAP based web services.
Support for OAuth2 tokens for outbound calls to external RESTful based web services.
Support for OAuth2 tokens for the mobile framework.
Note: This capability supports Security Assertion Markup Language (SAML) 2.0 but is limited to authentication only. Authorization is supported in the product using the Security Model.
Note: WLST commands in this section are for illustrative purposes only and assume that the user has connected to the relevant domain using the relevant WLST commands prior to execution of the command with the relevant credentials.
