Additional Security Resources
In addition to the security resources described in this guide, Oracle Utilities Application Framework provides the following additional security resources:
• Oracle Database Vault: Oracle Database Vault provides fine-grained access control to your sensitive data, including protecting data from privileged users. Oracle Database Vault Administrator's Guide and
Database Vault Integration (Doc Id:
1290700.1) describes how to use Oracle Database Vault.
• Oracle Audit Vault: Oracle Audit Vault collects database audit data from sources such as Oracle Database audit trail tables, database operating system audit files, and database redo logs. Using Oracle Audit Vault, you can create alerts on suspicious activities, and create reports on the history of privileged user changes, schema modifications, and even data-level access. Oracle Audit Vault Administrator's Guide explains how to administer Oracle Audit Vault and
Audit Vault Integration (Doc Id:
1606764.1).
• Oracle Advanced Security: See Oracle Database Advanced Security Administrator's Guide for information about advanced features such as transparent data encryption, wallet management, network encryption, and the RADIUS, Kerberos, Secure Sockets Layer authentication.
