tangosol-coherence-override.xml
The tangosol-coherence-override.xml file is generated using the templates located in the templates directory.
There are four templates for this file:
Template
Contents
tangosol-coherence-override.mc.be.template
Multicast Overrides (for Configuring Batch Using Bedit)
tangosol-coherence-override.ss.be.template
Single Server Overrides (for Configuring Batch Using Bedit)
tangosol-coherence-override.wka.be.template
WKA Overrides (for Configuring Batch Using Bedit)
tangosol-coherence-override.xml.template
General Overrides
The format and structure are set up for the implementation of Oracle Coherence for the batch infrastructure within the product.
Note: This file is fixed in format and should not be altered unless instructed by Oracle Support.
