Attribute | Comment |
Name | Allocate a name for monitoring and management purposes. |
JNDI Name | Allocate a name to be used by the connection. This is used as <datasourcename> later. It is recommended that the name be prefixed with jdbc/ to conform to naming standards. |
Row Prefetch Enabled | This should be enabled. |
Row Prefix Size | Specify a value between 2 - 100. Default: 48 |
Stream Chunk Size | This is not used by the product. |
Database Type | Specify Oracle. |
Database Driver | Specify the database driver to use. Do not use the XA versions of the driver for the product. By default, use the Thin driver for service connections. |
Supports Global Transactions | Deselect this option. It does not apply. |
One Phase Commit | Ensure this option is selected. |
Database Name | Specify the Oracle SID of the database to connect to. This should correspond to DBNAME - Database Name in the ENVIRON.INI. |
Host Name | Specify the host allocated to Oracle. This should correspond to DBSERVER - Database Server in the ENVIRON.INI. |
Port | Specify the Oracle Listener Port number of the database to connect to. This should correspond to DBPORT - Database Listener Port in the ENVIRON.INI. |
Database User Name | Specify the product database user. This should correspond to DBUSER - Online Database User in the ENVIRON.INI. |
Password | Specify the password for the user. This should correspond to DBPASS - Online Database User Password in the ENVIRON.INI. |
Initial Capacity | This is the initial size of the connection pool. |
Maximum Capacity | This is the maximum size of the connection pool. |
Capacity Increment | This is the number of connections that are added to the connection pool when necessary. |
Statement Cache Type | This denotes the type of cache to use. Use the LRU setting. |
Statement Cache Size | This is the cache size. |
Setting | Recommendation |
IWS JDBC DataSource Name | Fully qualified JNDI Name for Web Services Data Source. |
Web JDBC DataSource Name | Fully qualified JNDI Name for Web Data Source. |
