Field | Description |
Security Type | Identifier for Security Code. |
Description | A brief description of the use of the Security Code. |
Authorization Levels | A list of codes (Authorization Level) and associated descriptions. Use the Add icon to add a new Authorization Level or use the Delete icon to remove an existing Authorization Level from the list. The Authorization Level values are free format but should be representative of the desired function. The Description is used to explain the value. |
Application Service Id | A list of associated Application Services to use this Security Code. Use the Add icon to add a new Application Service or use the Delete icon to remove an existing Application Service from the list. |
