Facility | Comments |
Default User in Message Option | This is used for XAI and MPL (older releases only). |
HTTP Login User context type on Message Sender | Used for Utilities P2P integrations. Ensure HTTP User Password is also set correctly for alternative. |
WEB_IWS_SUPER_USERS in ENVIRON.INI file | Used for supporting IWS user proxy connections |
WEB_IWS_MDB_RUNAS_USER in ENVIRON.INI file | Used to support user proxy connections in Message Driven Bus. |
Batch Controls | Replace SYSUSER as the user used for submission of any batch controls in batch control configuration files, batch edit configuration files or in the Oracle Scheduler configuration. |
