Embedding User Experience
The product supports embedding application and being embedded in applications. To use this facility several settings must be configured appropriately including:
• Set embedded behavior. Set the following values in the spl.properties file used for the online:
• Set the URI substitutions. Set the substitution variables for your embedded or embedding application to avoid hardcoding in the file indicated in com.oracle.ouaf.uriSubstitutionVariables.file. For example:
<?xml version="1.0" encoding="UTF-8"?>
<substitutionVariables>
<uriVariable>
<name>CSP_FRAME_ANS_HOST1</name>
<value>https://[FRAMING-HOST-URL]</value>
</uriVariable>
<uriVariable>
<name>CSP_FRAME_ANS_HOST2</name>
</uriVariable>
</substitutionVariables>
