Field | Comments |
Redaction Function | Identifier for function. Must be prefixed with CM for custom function entries to avoid conflicts with base provided functions |
Description | Short description for function |
Override Description | Override description to allow implementations to override short description of base provided functions |
Detailed Description | Detailed description of function |
Status | Status of function. Valid Values: • Active. Function is available for use. • Inactive. Function is not available for use. Only Active functions are applied. |
Function Type | Type of function. Valid Values are: • Date Mask used to mask dates • Number Mask to mask numbers • Regular Expression to mask general fields • String Mask to mask strings |
Date Mask | Mask of date in ISO format. For example: YYYY-01-01 sets all dates where this function is used to the first day of the year of the record. |
Start Offset | Start position offset in field for Number Mask and String Mask |
End Offset | End position offset in field for Number Mask and String Mask |
Replacement Digit | Digit to use as replacement between start and end offset for Number Mask |
Regular Expression | Regex expression to find values within data for Regular Expression Mask |
Replacement Expression | Regex expression to replace values found in regular expression for Regular Expression Mask |
Replacement Character | Character to use as replacement in between start and end offset for Number Mask |
Digits Only | Replace Digits only in string. Used for String Mask only. For example, replacing digits in phone numbers. |
