hibernate.properties
The hibernate.properties file defines the connection to the database and the Object to Relational database mapping.
hibernate.cache.use_second_level_cache - Use Cache
Parameter
Description
Enable or Disable the second level cache, which is enabled by default for classes which specifies a cache mapping. This is disabled by default as Oracle Utilities Application Framework includes its own cache.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Maintained by product templates. Use Implementing Custom Templates to implement a different value.
Applicability
Business Application Server, Inbound Web Services, Background Processing.
Example:
hibernate.cache.use_second_level_cache = false
hibernate.connection.datasource - JNDI Data Source
Parameter
Description
Enables Data Source support and indicates JNDI data source. This is an alternative to UCP. See JDBC Support for more information. JNDI data sources cannot be used for batch processing.
Ordinality
Mandatory
Valid Values
JNDI path to data source.
Source
Applicability
Business Application Server, Inbound Web Services.
Example:
hibernate.connection.datasource=jdbc/ouafdb
hibernate.connection.driver_class - Connection Driver Class
Parameter
Description
Driver class used by Hibernate.
Ordinality
Mandatory
Valid Values
Valid Driver Class. Default: oracle.jdbc.driver.OracleDriver
Source
Applicability
Example:
hibernate.connection.driver_class = oracle.jdbc.driver.OracleDriver
hibernate.connection.password - Database User Password
Parameter
Description
Encrypted password for Database User
Ordinality
Mandatory
Valid Values
Generated Database Password. Value depends on channel:
Online uses DBPASS
Batch uses BATCH_DBPASS
Source
Maintained by product templates. Set appropriate value for user required in required parameter.
Applicability
Example:
hibernate.connection.password = ENCKS(….)
hibernate.connection.provider_class - Connection Provider
Parameter
Description
Connection Provider Class for Hibernate. Use the default UCP provider as supplied unless using JBDC Data Sources where com.hibernate.connection.DatasourceConnectionProvider is used instead.
Ordinality
Mandatory
Valid Values
Generated Provider Class. Default: com.splwg.shared.common.UCPConnectionProvider
Source
Applicability
Example:
hibernate.connection.provider_class= com.splwg.shared.common.UCPConnectionProvider
hibernate.connection.release_mode - Connection Release
Parameter
Description
This parameter controls when a connection is released to the pool. By default the value is set to after_transaction. Whilst other values can be used, for consistency of the connection it is recommended to use the default.
Ordinality
Mandatory
Valid Values
Generated Release Mode. Default: after_transaction
Source
Applicability
Example:
hibernate.connection.release_mode=after_transaction
hibernate.connection.url - JDBC URL
Parameter
Description
JDBC URL for connection to database.
Ordinality
Mandatory
Valid Values
Generated URL or using override database connection.
Source
Maintained by product templates. Use DB_OVERRIDE_CONNECTION for specific values.
Applicability
Example:
hibernate.connection.url = jdbc:oracle:thin:@ouafdemo.dbserver.com:1522:/MYPDB
hibernate.connection.username - Database User
Parameter
Description
JDBC User for connection.
Ordinality
Mandatory
Valid Values
The value depends on the channel accessed:
Online uses DBUSER
Batch uses BATCH_DBUSER
Source
Applicability
Example:
hibernate.connection.username=CISUSER
hibernate.dialect - Dialect Used
Parameter
hibernate.dialect
Description
This is the SQL dialect (database type) for the database being used. Any valid Hibernate dialect may be used. Refer to http://www.hibernate.org/hib_docs/v3/api/org/hibernate/dialect/package-summary.html for a full list.
Ordinality
Mandatory
Valid Values
Generated Dialect.
Default: org.hibernate.dialect.Oracle10gDialect.
Source
Applicability
Example:
hibernate.dialect=org.hibernate.dialect.Oracle10gDialect
hibernate.jdbc.batch_size - JDBC2 Update Support
Parameter
Description
A non-zero value enables use of JDBC2 batch updates by Hibernate.
Ordinality
Mandatory
Valid Values
Generated Value. Default: 30.
Source
Applicability
Example:
hibernate.jdbc.batch_size=30
hibernate.jdbc.fetch_size - Solution Set Size
Parameter
Description
Determines a hint to the JDBC driver on the the number of rows to return in any SQL statement. This is overridden at runtime on zone parameters and commit interval.
Ordinality
Mandatory
Valid Values
Generated Value. Default: 100.
Source
Applicability
Example:
hibernate.jdbc.fetch_size=100
hibernate.max_fetch_depth - Join Fetch Depth
Parameter
Description
Sets a maximum depth for the outer join fetch tree for single-ended associations (one-to-one, many-to-one). A 0 disables default outer join fetching
Ordinality
Mandatory
Valid Values
Generated Value. Default: 2.
Source
Applicability
Example:
hibernate.max_fetch_depth=2
hibernate.query.factory_class - HQL Parser
Parameter
Description
The classname of a Querey Factory to use for HQL parsing.
Ordinality
Mandatory
Valid Values
Generated Value. Default: org.hibernate.hql.internal.classic.ClassicQueryTranslatorFactory
Source
Applicability
Example:
hibernate.query.factory_class= org.hibernate.hql.internal.classic.ClassicQueryTranslatorFactory
hibernate.query.substitutions - Literal Mappings
Parameter
Description
Mapping from tokens in Hibernate queries to SQL tokens (tokens might be function or literal names, for example).
Ordinality
Mandatory
Valid Values
[true 'Y'|false 'N']
Source
Applicability
Example:
hibernate.query.substitutions = true 'Y', false 'N'
hibernate.show_sql - Debug Mode
Parameter
hibernate.show_sql
Description
Use of Debug Mode for all SQL Statements. It is highly recommended not to enable debug at this level.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
hibernate.show_sql = false
hibernate.transaction.factory_class - Transaction Class
Parameter
Description
The classname of a Transaction Factory to use with Hibernate Transaction API.
Ordinality
Mandatory
Valid Values
Generated Value. Default: org.hibernate.transaction.JDBCTransactionFactory
Source
Applicability
Example:
hibernate.transaction.factory_class = org.hibernate.transaction.JDBCTransactionFactory
hibernate.ucp.connection_wait_timeout - UCP Connection Timeout
Parameter
Description
Specifies how long, in seconds, an application request waits to obtain a connection if there are no longer any connections in the pool
Ordinality
Mandatory
Valid Values
Generated Value. Default: 5.
Source
Applicability
Example:
hibernate.ucp.connection_wait_timeout=5
hibernate.ucp.inactive_connection_timeout - Connection Inactivity Timeout
Parameter
Description
Specifies how long, in seconds, an available connection can remain idle before it is closed and removed from the pool.
Ordinality
Mandatory
Valid Values
Generated Value. Default: 300.
Source
Applicability
Example:
hibernate.ucp.inactive_connection_timeout=300
hibernate.ucp.jmx_enabled - Enable UCP JMX
Parameter
Description
Enable or Disable JMX Mbeans for UCP. The Mbeans will appear as additional classes on the existing JMX capabilities for that tier.
Ordinality
Mandatory
Valid Values
[true|false]
Source
Applicability
Example:
hibernate.ucp.jmx_enabled=false
hibernate.ucp.max_size - Maximum Pool Size
Parameter
Description
Maximum Pool size for this teir. Maximum number of active connections to the database.
Ordinality
Mandatory
Valid Values
Generated. Default: 30
Source
Applicability
Example:
hibernate.ucp.max_size=30
hibernate.ucp.max_statements - SQL Buffer Size
Parameter
Description
Number of statements cached for performance on this teir.
Ordinality
Mandatory
Valid Values
Generated. Default: 50
Source
Applicability
Example:
hibernate.ucp.max_statements=50
hibernate.ucp.min_size - Minimum Pool Size
Parameter
Description
Initial Connection Pool size for this tier.
Ordinality
Mandatory
Valid Values
Generated. Default: 1
Source
Applicability
Example:
hibernate.ucp.min_size=1
