Name | Type | Description |
mail.debug | Boolean | The initial debug mode. Default is false. |
mail.from | String | The return email address of the current user, used by the InternetAddress method getLocalAddress. To ensure that the value of the mail.from property is handled properly when set through a user exit include file, add a '\' (backslash) in front of the '@' symbol. For example, if the value desired for mail.from is demo@orgname.org then it should be set as demo\@orgname.org |
mail.host | String | The default host name of the mail server for both Stores and Transports. Used if the mail.protocol.host property isn't set. |
mail.mime.address.strict | Boolean | The MimeMessage class uses the InternetAddress method parseHeader to parse headers in messages. This property controls the strict flag passed to the parseHeader method. The default is true. |
mail.smtp.class | String | Specifies the fully qualified class name of the provider for the specified protocol. Used in cases where more than one provider for a given protocol exists; this property can be used to specify which provider to use by default. The provider must still be listed in a configuration file. |
mail.smtp.host | String | The host name of the mail server for the specified protocol. Overrides the mail.host property. |
mail.smtp.port | int | The port number of the mail server for the specified protocol. If not specified, the protocol's default port number is used. |
mail.smtp.user | String | The username to use when connecting to mail servers using the specified protocol. Overrides the mail.user property. |
mail.smtp.password | String | The password to use when connecting to mail servers using the specified protocol. |
mail.store.protocol | String | Specifies the default message access protocol. The Session method getStore() returns a Store object that implements this protocol. By default, the first Store provider in the configuration files is returned. |
mail.transport.protocol | String | Specifies the default message access protocol. The Session method getTransport() returns a Transport object that implements this protocol. By default the first Transport provider in the configuration files is returned. To enable SSL, set this property to "smtps". |
mail.debug | String | Specifies the debug mode is enabled. |
mail.user | String | The default username to use when connecting to the mail server. Used if the mail.protocol.user property isn't set |
