Defining Key Rings
Refer to
Understanding Key Rings for an overview of key ring functionality.
To maintain the key rings applicable to your product or implementation, open > >
This is a standard
All-in-One portal and includes the standard List and display zones for a key ring.
The information captured on the key ring depends on the business objects supported by your product or implementation. Refer to the embedded help text for more information.
Key Zones
The key zone provides information about the keys that are associated with the key ring. The zone display and available actions depend on the type of key. Refer to embedded help for more information.
Parent topic
