Defining Insight Types
The insight type entity is used to define the configuration of a specific type of alert to display extra information related to one or more records in context. Refer to
Insight Types for a detailed description of the supported functionality.
To view or maintain insight types, open > >
This is a standard
All-in-One portal.
The information captured on the insight type depends on the record's business object. Refer to the embedded help text for more information.
Related Insight Groups
If there are any insight groups that reference this insight type, the Related Insight Groups zone displays the linked insight groups.
Parent topic
