Maintenance Object - Main
Navigate to > > to view information about a maintenance object.
Use the Maintenance Object Query portal to search for an existing maintenance object. Once a maintenance object is selected, you are brought to the maintenance portal to view and maintain the selected record.
Description of Page
Most maintenance objects are provided with the base package. An implementation can introduce custom maintenance objects when needed. Most fields may not be changed if owned by the base package.
Enter a unique Maintenance Object name and Description. Owner indicates if this business object is owned by the base package or by your implementation (Customer Modification).
Important:
If you introduce a new maintenance object, carefully consider its naming convention. Refer to
System Data Naming Convention for more information.
Service Name is the name of the internal service associated with the maintenance object.
The grid displays the following for each table defined under the maintenance object:
• Table is the name of a given table maintained as part of the maintenance object.
• Table Role defines the table's place in the maintenance object hierarchy. Only one Primary table may be specified within a maintenance object, but the maintenance object may contain many Child tables.
• Owner indicates if this is owned by the base package or by your implementation (Customer Modification).
Parent topic
