Business Event Log
Business Event Log may be viewed as a tool designed to capture any type of business event worth noting. You configure business objects to represent the various types of events your application calls for. The following type of details may be captured for each event:
• The business object representing the type of event.
• The date and time the event took place and who initiated it.
• The business entity for which this event is logged.
• Standard application message to describe the event.
• Additional context information that is available at the time of the event and varies for each type of event. The Business Event Log maintenance object supports a standard characteristics collection as well as an XML storage (CLOB) field. The event's business object determines where each piece of information resides. Refer to
 Business Objects for more information.
 One common type of event may be the audit of changes made to sensitive data, for example, tracking an address change. Whenever an entity associated with a business object is added, changed, or deleted the system summarizes the list of changes that took place in that transaction and hands them over to
Audit business object algorithms to process. You may design such an algorithm to audit the changes as business event logs. Refer to
a business object may define business rules for more information.
You can also allow users to initiate business event logs to capture important notes about a business entity by exposing a
 BPA Script to invoke the event's corresponding business object.
Bottom line is that any process can create a business event log by invoking the business object representing the appropriate type of event.
Parent topic
