Data Area - Schema
Use this page to maintain a Data Area's schema and to see where the data area is used in the system. Open this page using  >  >  and then navigate to the Schema tab.
Description of Page
The contents of this section describe the zones that are available on this portal.
The General Information zone displays the main attributes of the data area.
The
Schema Designer zone allows you to edit the data area's schema. The purpose of the schema is to describe the structure and elements of the data area.
Fastpath:
Refer to
Schema Syntax and
UI Hint syntax for a complete list of the XML nodes and attributes available to you when you construct a schema. Also note that the
Schema Tips zone in the dashboard provides links to launch these help topics directly.
 Note:View UI Rendering. A context sensitive "View UI Rendering" zone is associated with this page. The zone is useful for data areas that are to be included in
business objects that define the user interface detail using schema attributes and UI Hints. The buttons allow you to view the automatically rendered display and input maps.
 The
Schema Usage Tree zone summarizes all cross-references to this schema. These may be other schemas, scripts, and web services. For each type of referencing entity, the
tree displays a summary node showing a total count of referencing items. The summary node appears if at least one referencing item exists. Expand the node to list the referencing items and use their description to navigate to their corresponding pages.
Parent topic
