About Load Data
Load Data details the measurements of the output flow as represented in the following columns:
• Flow - Displays the energy brought in from outside over the indicated hour.
• Gen - Displays the energy generated by the specific municipality over the past hour.
• Load - Displays the energy that the municipality delivered to customers over the past hour.
• Forecast - Displays the energy forecast to be delivered to the customer over the past hour.
• Differential - Displays the difference between the actual load and the forecast load.
