Maintaining Alerts
The Alert portal is used to display and maintain alerts. Refer to About Alerts for additional functional information.
You can access the portal by selecting Menu, then Historian, then Alert. A query portal opens with search options. After you select your record, you are taken to a maintenance portal to view and maintain the selected record.
The following zone may appear as part of the portal's Main tab page:
Alert: This zone displays the basic attributes of the alert.
To define a new alert:
1. From the menu. Select Historian, Alert, and select Add.
2. Select an Alert Type from the drop-down menu and click OK.
3. You must complete the required fields. Notice, for the Characteristics section, you will see asterisks next to the fields. These fields are only required if you click the plus sign (+) to add these items. However, by default, these sections are not required to define an alert.
4. Click Save to finish adding the new alert.
