Live Energy Connect Portal
The Live Energy Connect Portal gives you quick access to real-time data about your assets using a dashboard. The dashboard is intuitively designed to help you quickly review the status and metrics of your assets and send you alerts if the status of an asset changes.
To access the Live Energy Connect Portal, from the menu, select Historian and select Live Energy Connect.
Parent topic
