Menu Suppression
In addition to the above Menu Item Suppression logic, the following points describe how your module configuration can suppress an entire menu.
Menus that are owned by the base product (as opposed to those your implementation adds) are associated with one or more function modules.
If your module configuration has turned off all of the menu's modules, the entire menu is suppressed. If at least one of the modules is accessible, i.e. turned on, the menu is not suppressed.
