Viewing Erasure Configuration
The Erasure Configuration All-in-One portal provides the ability to view the maintenance objects that are marked as eligible for erasure and maintain their erasure configuration entries in a single place.
To view a list of the eligible MOs, open Admin > Security > Erasure Configuration.
Press the edit icon to open a window in which the configuration values for that row can be changed.
Refer to The Approach to Implementing Object Erasure for an overview of object erasure configuration.
