Defining Colors
The system provides the
extendable lookup Color (
F1-Color) to define valid colors to be used in the system. The base colors provided are ones related to the standard color palette used in Oracle products.
At this time, zones and UI maps that define specific colors do not support any syntax to reference a color extendable lookup. In the meantime, colors applied at the zone or map level can still reference HTML colors or reference hex codes directly.
Parent topic
