Defining Lookups
Lookup fields may be used to define valid values for a column in a table or for other types of values like parameters to an algorithm.
Fastpath:
Refer to Defining Valid Values for some background information.
The base product provides many different lookup fields and their values as part of the product. The following points highlight some functionality related to base-package lookups.
Fields that are owned by the product will typically provide base lookup values. Implementations are not permitted to remove base delivered lookup values. Implementations may be able to add custom values to base owned lookups. This is controlled with the Custom switch on lookup.
When the custom switch is unchecked, it means that there is functionality controlled by the base values and an implementation may not extend or customize this functionality. An example of this type of lookup is the Data Type field on the Field table. The system supports a distinct list of data types and an implementation may not add additional values.
When the custom switch is checked, it means that there is base functionality supplied for the base values but that an implementation can extend the functionality by supplying their own values. An example of this type of lookup is the Access Mode on Application Service. The product provides many values for the access mode lookup, representing various actions a user may perform. Implementations may add their own values to this lookup. Documentation should indicate when functionality may be extended and should highlight the lookup value that can be extended.
CAUTION:
Important! If you introduce new lookup values, you must prefix the lookup value code with X or Y. If you do not do this, there is a possibility that a future release of the application could introduce a new lookup value with the name you allocated.
There may be some scenarios where the product supplies a base field and base lookup field with no base lookup values supplied. This occurs when the product doesn’t have any base functionality driven by the lookup values. Typically this type of lookup is for information or categorization purposes. The configuration guide for the functional area associated with the lookup should include a configuration step regarding defining values for this type of lookup.
The description of base delivered values may be overridden by an implementation.
An implementation may also identify the need for defining a new lookup field with its values.
