Archived Foreign Keys
If your DBA chooses to archive a partition, there may be records in the system that refer to one of the archived records as a foreign key.
When a user attempts to view a record using a hyperlink or drill down mechanism, if the implementation of the navigation uses FK Reference functionality, the system will first check if the record exists. If not, it will display a message to the user indicating that the record has been archived.
