Integration with BI Publisher
Your DBMS, your product, and BI Publisher can work together to produce reports. You may choose to use a different reporting tool, but this may not be a trivial effort. This section provides high-level information about some of the business requirements that are being solved with the reporting solution.
Multi-Language and Localization Support
The integration supports a multi-language implementation and supports different localization settings.:
All labels, headings and messages are defined using field and message meta-data in the application, which support multiple languages.
The appropriate font, size, and layout are based on the requested report and the user's language.
Dates and numbers are formatted as per the user's display profile.
Currency based numbers are formatted as per the currency definition from the product
