Understanding Analytics Integration
The following sections describe the type of configuration supported in your product to integrate with the analytics product. Refer to the Oracle Utilities Analytics documentation for more information.
Master Configuration
Edge applications that include an integration to the analytics product typically include a master configuration record that captures information needed for the extract, load and transformation step, such as extract parameters. These records are provided by the specific edge products and my be viewed and maintained on the master configuration portal.
Note that your specific edge application may deliver an Analytics Configuration portal that displays the information from the master configuration record along with other analytics related configuration.
Bucket Configuration
The analytics product provides support for defining a set of ranges, each representing a bucket for which extracted measures can be grouped and classified under the relevant bucket. The framework product provides support for viewing and defining the buckets. Refer to Bucket Configuration for more information.
ETL Based Characteristic Mapping
The product provides objects to allow mapping configuration of characteristics in the product to user defined fields on dimensions in the analytics product. The mapping is used by the extract process to populate target user defined columns with corresponding characteristic data.
This type of mapping relies on configuration in the Allowed Target Dimensions extendable lookup. The extendable lookup is used to define each Target Table in the analytics product that has one or more user defined fields that may be populated with characteristic values. It also defines the valid characteristic entities that may act as the source for the characteristic data.
The framework does not provide any values in this lookup, but edge products that support mapping provide values in this lookup. Please refer to your specific product’s integration chapter and refer to the Oracle Utilities Analytics documentation for more information.
Refer to Defining Analytics Attribute Mapping for more information.
Change Data Capture Using Sync Request
Depending on the specific edge application and version you are using, there may be components of the integration that use Sync Request for the change data capture step. If that functionality applies to your implementation, the following points highlight how to get more information:
Refer to the administration guide for Oracle Utilities Analytics to confirm if your product integration is using Sync Request for any change data capture functionality.
Review the Sync Request Business Objects provided by your product for analytics integration.
Refer to Data Synchronization for a high level understanding of the process.
