LDAP Integration
Organizations commonly use a Lightweight Directory Access Protocol (LDAP) security repository as a source of security credentials. The system provides support for importing users and groups from an external LDAP repository into the product to populate Users and User Groups in the system. Once imported, all user and group functions are available. You can resynchronize your LDAP users and groups at any time.
Note:Import only. The system currently supports importing LDAP information. Exporting users and groups from the system to LDAP is not provided.
Additional configuration. When importing new users and / or groups, additional configuration is needed in the base product. For example, after importing a new user group and its users, the user group configuration should be updated to define the valid application services for the user group. After importing a new user, additional configuration may be needed on the user such as valid To Do Roles, valid Home Page, etc.
Fastpath:
Refer to Defining Security and User Options for more information about the application security and what it controls.
This section the functionality provided in the framework application that supports LDAP. Refer to the LDAP Integration technical reference paper for more information about typical steps related to the full integration.
