Migration Object Portal
This page appears after drilling into a specific migration object from the migration data set portal or from the migration transaction portal.
Refer to
Importing and Applying a Migration for an overview of the import process.
The Migration Object zone contains display-only information about the selected record. Please see the zone’s help text for information about this zone’s fields.
The Migration Object - List of SQL Statements zone lists the SQL statements that have been generated as a result of the comparison step. A check mark in the Suppressed checkbox indicates that the SQL for that row will not be applied during the apply step.
The Migration Object - Algorithms zone displays any pre-compare algorithms that are associated with the migration plan for this migration object.
Parent topic
