Generalized Export Dashboard
The number of maintenance objects that are eligible for generalized export is large. This portal allows you to easily select and enable export for many eligible entities at once as well as review the current export state of those already enabled at a glance.
You can access the portal from the Admin Menu > Implementation Tools > Generalized Export Dashboard.
The following zones may appear as part of the portal's Main tab page.
Export Entities. This zone lists entities for which generalized data export control settings have already been set.
Eligible Entities. This zone lists entities that are eligible for the generalized data export method and for which such settings have not yet been set.
