Business Object - Summary
This page summarizes business object information in a high level. Open this page using  >  >  >  and then navigate to the Summary tab.
Description of Page
The contents of this section describe the zones that are available on this portal.
The General Information zone displays main attributes of the business object.
Click the
View Schema hyperlink to view the business object's expanded schema definition. Doing this opens the
schema viewer window.
Click the View XSD hyperlink to view the business object's expanded schema definition in XSD format.
The
Business Object Hierarchy zone displays in a tree view format the
 hierarchy of child business object associated with the current business object. It also shows the current business object's immediate parent business object.
For business objects with a lifecycle, the Lifecycle Display zone shows a graphical depiction of the lifecycle. Refer to the embedded help of that zone for more information.
The
Options zone summarizes business object and state specific options throughout the
 inheritance chain.
The
Rules zone summarizes business object and state specific rules throughout the
 inheritance chain.
Parent topic
